he hallo allemaal
mijn led vu meter werkt niet!!
dit is het schema wat er bij hoort:
en dit de code:
c code:
// Led VU Meter Example
// Version 1.0
// Written by James Newbould
int led[10] = { 3, 4, 5, 6, 7, 8, 9, 10, 11, 12}; // Assign the pins for the leds
int leftChannel = 0; // left channel input
int left, i;
void setup()
for (i = 0; i < 10; i++) // Tell the arduino that the leds are digital outputs
pinMode(led[i], OUTPUT);
// Serial.begin(9600); // Uncomment to enable troubleshooting over serial.
void loop()
left = analogRead(leftChannel); // read the left channel
// Serial.println(left); // uncomment to check the raw input.
left = left / 50; // adjusts the sensitivity
// Serial.println(left); // uncomment to check the modified input.
// left = 1500; // uncomment to test all leds light.
// left = 0; // uncomment to check the leds are not lit when the input is 0.
if (left == 0) // if the volume is 0 then turn off all leds
for(i = 0; i < 10; i++)
digitalWrite(led[i], LOW);
else
for (i = 0; i < left; i++) // turn on the leds up to the volume level
digitalWrite(led[i], HIGH);
for(i = i; i < 10; i++) // turn off the leds above the voltage level
waar gaat het fout??.
[Bericht gewijzigd door Henry S. op donderdag 14 november 2013 18:26:45 (0%)
