This excellent info requires an Excel spreadsheet!
Regards from Cyprus.
David
David
There is a spreadsheet link in the startpost, although it has not been updated for a while...
Hi Jochem,
Thanks for that.
All I need now is to change the titles to Dutch
Auto-translate does not access Excel file LOL.
David
Even tussendoor..
Fabrikant: Seeedstudio.com
Special option: V-CUT(Free V-CUT, only straight lines)
Panelizing: JA (x35)
Aantal besteld: 10
Ontvangen: (Schrik niet:) 14 Mazzel
Afmeting: 10 x 10 cm dubbelzijdig
Kleur: Zwart
Prijs 14 stuks: $44.90
Verzending via Registered Air Parcel $9.37
Levertijd: 20 dagen van bestellen tot ontvangen
Kwaliteit: Perfect.
Doel: Top Secret !! Zelfs Rutte en zijn vriendjes weten hier niets van.
Front Side:
Back Side
serial RGB-led
Op 8 september 2014 10:34:38 schreef Jochem:
Jochem or anyone,
Could you please translate the headings along the top row of the pcb suppliers file for me into English as I'd like to edit my downloaded copy and get it out to a few colleagues who may wish to followup?
Here are the words:
Some Dutch words u
nder the above heading to describe the quality are also foreign to me such as:
Many thanks
David
Edit: darn, only after posting this message I discovered leime had done some translations while I was typing..
Oh well, I also translated the other set of phrases
Here goes...
1. Fabrikant (I think this is Fabricator)
Manufacturer
2. Aantal besteld
Quantity (number of PCBs) ordered
3. Afmeting X (mm)
Dimensions X (millimeter)
4. Afmeting Y (mm)
Dimensions Y (millimeter)
5. Prijs (p/s) (I know this is Price but what is p/s)?
Price (a piece / per single PCB)
6. Verzendkosten
Shipping cost
7. Levertijd (dagen)
Delivery time / lead time (days)
8. Aanteal ontvangen
Quantity received (sometimes differs from what was ordered)
9. Aantal bruikbaar
Number of usable PCBs (sometimes some PCBs are of such bad quality they cannot be used)
10. Kwaliteit (I think this is Quality)
(Overall) quality
1. silk aanvaardbaar
Silkscreen is acceptable (silk is not always perfectly aligned, in this case it is also not perfect, merely acceptable for its goal)
2. uitstekend
Excellent
3. maar het duurt wat lang
..although it took quite some time (e.g. shipping)
4. goed, prijs is ok en service laat wat te wensen over
Good - price is okay but service falls short
5. matig, geen enkel board vrij van touch-ups
moderate/mediocre - not a single board without touch-ups
6. erg goed zeker gezien de prijs
Very good, especially considering the price
7. zeer goed en ruim dubbel ontvangen
Very good, and received more than double (quantity, I guess)
8. goed, silk van 4 printen verschoven
Good - silk(screen) of 4 PCBs had incorrect offset
9. goed, silk soms verschoven en rare vlek op 1 print
Good - silk(screen) sometimes (for some PCBs) shifted/incorrect offset, and weird spot/stain on 1 PCB
Many thanks
You're welcome
I think in this particular case Google Translate might have been of some help.
Thanks guys,
Makes things easier for sure.
I decided for such a short translation that human rather than robot would be better.
Thank you again.
David
OK, I've edited my copy but have a further question.
I gather the Link & UBB is related to the original post and order placed?
It takes up a lot of space.
Would it not be simpler to just have the Manufacturers site url and leave the comments at the end as normal?
I will need an AM transmitter lcd controller board designed and have other RF related projects on the go.
Thank you again.
David
Fabrikant: iTead
Aantal besteld: 350, 700+ ontvangen
Afmeting (in millimeters): 54.2 x 48
Prijs per stuk: $0.40 indien 350 stuks geleverd, $0.20 aangezien er 700 geleverd zijn
Verzendkosten: $67 (met DHL)
Levertijd (in dagen van bestellen tot ontvangen): 14
Bruikbaarheid (aantal bruikbaar / aantal ontvangen, bijv: 7/10): vermoedelijk allemaal
Kwaliteit (perfect, goed, matig, slecht, bizar): Prima
Het lijkt erop dat ze mijn order per ongeluk twee keer gefabriceerd hebben...
BTW factuur komt overigens nog met de post, dus er komt waarschijnlijk nog 21% bij.
Op 24 september 2014 13:11:09 schreef Transmitter Man:
I gather the Link & UBB is related to the original post and order placed?It takes up a lot of space.
I don't really see the problem here. It's your copy. Just leave out those two columns if you don't need them.
Fabrikant: iTead
Aantal besteld: 10 blauw 13 geleverd
Afmeting (in millimeters): 100 X 70
Koper: 1oz
Surface finish: ENIG
Prijs per stuk: $4,21
Kwaliteit (perfect, goed, matig, slecht, bizar): perfect
(klikbaar)
Aantal besteld: 20 blauw 24 geleverd
Afmetingen (in milimeters): 100 X 80
Koper: 2oz
Surface Finish: ENIG
Prijs per stuk: $6,661
(klikbaar)
Aantal besteld: 20 rood 23 geleverd
Afmetingen (in milimeters): 90 X 75
Koper: 2oz
Prijs per stuk: $6,91
(klikbaar)
Verzendkosten: $49 (met DHL)
Levertijd (in dagen van bestellen tot ontvangen): 231
1Voor het eerst BTW en douanekosten (71€38) moeten betalen. Was de eerste zending via DHL. Goederen zijn op 15 dagen (maandag) in België toegekomen. DHL heeft me pas 2 dagen later voor het eerst gecontacteerd. Ik was zelf niet thuis. De belofte de volgende voormiddag terug te bellen hebben ze niet waargemaakt. Pas op vrijdag mij terug gebeld. Onmiddellijk de kosten overgeschreven. Op maandag levering thuis gekregen.
Volgende zending zal terug per post zijn en in kleinere hoeveelheden. Kans op kosten verkleint zo drastisch.
[Bericht gewijzigd door buckfast_beekeeper op maandag 29 september 2014 16:06:58 (13%)
Daarom is het beter om de producten te bestellen met tussenpozen van twee dagen zodat je net onder de importgrens zit. Dan hebben zij geen kans meer om de bestellingen samen te voegen tot één.
Het ligt ook aan de vervoerder. Soms zat ik net op randje (bij Seeedstudio) van importkosten. DHL berekende het wel terwijl FedEx het gewoon bezorgde. Het gaat hierbij dan wel om minimale afwijkingen van een dollar ofzo.
Volgens postnl:
U betaalt btw, douanerechten en inklaringskosten:
Bij commerciële zendingen met een waarde hoger dan 22 euro. ($28.22)
Bij geschenken met een waarde hoger dan 45 euro. ($57.72)
Doaune (belastingdienst) zegt het volgende:
Minder dan 22 euro: U betaalt geen belastingen bij het invoeren van uw internetaankoop.
Tussen de 22 en 150 euro: U betaalt geen invoerrechten (douanerechten) bij het invoeren van uw internetaankoop, wel btw. De btw bedraagt 21%, 6% of niets.
Ik had er gewoon 1 bestelling van gemaakt. Volgens DHL is het in België 22€. Als ik dan op de itead website kijk is het alleen in groen en max 10 printjes 10 X 10. Neem je ENIG als finish, dan kom je er al niet meer in 5 X 5. Dikker koper is dan ook niet mogelijk.
Met de post kwamen mijn gekleurde printjes altijd aan zonder extra kosten.
Verzending per DHL betekent gegarandeerd BTW betalen. Simple as that
Tommyboy en buckfast_beekeeper, waar zijn de foto's of zijn ze 'top secret'.
/ik/ heb geen fotos. 5 september besteld, 12 september aangemeld bij DHL, "stuck in customs"....
Als ik het goed begrepen heb, is der een douane afdeling die alleen DHL related pakketjes afhandelt. DIE zijn betrokken bij een juwelen/vals-geld smokkel, en even op nonactief gesteld.
Mijn pakketje hangt dus volgens DHL nog steeds in "shipment info received", en fysiek bij de douane op de grens tussen China mainland en Hongkong.
Foto's zal voor maandag zijn. Op het werk kan ik ze deftig scannen naar BMP.
Er is niks geheim aan. Van de eerste 10 heb ik er slechts 2 nodig. Interface tussen S88 en PC LPT ingang voor gebruik met MR-direct. De 20 blauwe zijn de S88 bezetmelders met stroomdetectie. De rode zijn in eerste plaats bedoelt als DCC wisseldecoder op basis van een ATtiny861. Met een andere programmering kunnen ze uiteraard voor andere zaken ingezet worden. 1 schoonheidsfoutje hebben ze allemaal. Vergeten eerst nog een keer op te slaan voor ik de gerbers maakte. Nu staat er overal not saved ipv de datum.
Op 25 september 2014 10:24:14 schreef Ruud Harmsen:
Ze zijn voor mijn werk, ik vind het niet zo netjes om dan foto's te posten.
Fabrikant: Oshpark
Panelizing: Nee
Aantal besteld: 6
Ontvangen: 6
Afmeting: 15mm
Kleur: Paars
Prijs 6 stuks: $3.8
Verzending via inclusief
Levertijd: 16 dagen van bestellen tot ontvangen
Kwaliteit: Printen zien er prima uit.
Waarmee de pcb vastzat in het paneel moet ik er wel nog afvijlen.
Doel: PR4401 led driver voor in een zaklamp zodat ik een witte led kan laten branden op een AA.
Helaas heb ik het soldeermasker verpruts voor de onderkant(links op de foto) en zijn ze niet bruikbaar tenzij ik het soldeermasker er afkan halen aan een kant. (iemand tips?)
@buckafast: je afstand tussen de + en de wisselspanning is wel zeer klein van het rode pcb, al is het laagspanning, zou daar toch even met een dremel ofzo tussen gaan
Ik verwacht daar heel weinig problemen. Is netjes door de Itead DRC geraakt.
Die Itead DRC gaat echt geen rekening houden met de benodigde clearance. Die kijken alleen maar of ze het kunnen maken of niet.
